Modal analysis with rigid elements
    • glouvincs01
      I would like to know if it is possible to perform a modal analysis with an assembly composed of rigid elements? My first results show a very high frequency about 10^5 hz...
      thank you for your answer,
      Best,
    • Wenlong
      Do you mean you want to study the mechanism of a rigid body system? Like several rigid bodies connected by joints?
      Wenlong
    • glouvincs01
      Hi Wenlong,
      thanks for your help.
      I have 3 bodies: One rigid body which is connected to another rigid body by a flexible body.
      I would like to get the resonance frequency of the whole system, it is possible ?
    • Wenlong
      Yes, mixing rigid bodies and flexible bodies is possible in modal analysis.
      Wenlong
Viewing 3 reply threads
