Modal solution
    • ansysuser2020
      Can not get correcr results in modal ansys
      can you help?
      it is first mode
    • peteroznewman
      Please reply with a description of what you think are the correct results.
    • ansysuser2020
      I think it is not correct results. Before I instal linear type of mesh elements and results was good.
    • peteroznewman
      Please show the mode shape for the linear elements that you though looked good.
      Also show the mesh.
    • ansysuser2020
    • ansysuser2020
    • peteroznewman
      The first image is Mode 3 at 2237 Hz, while the image above is Mode 1 at 848 Hz.  They have different shapes because they are different modes. I expect you will get the same mode shapes and the same modal frequencies when you mesh with Linear or Quadratic elements. Just be careful to compare the same Mode.
Viewing 6 reply threads
