Modal Superposition: Adding Mode Deformation Results
    • Brett D
      Hey guys,
      I've got a Modal analysis where I've solved for the first 6 modes and I've extracted the deformation for each one. Pretty standard so far. I'm looking to add the mode shape deflections together.
      Basically I want to create a result/user defined result (I think):
      My_result = 0.1*(Deformation of Mode1) + 0.3*(Deformation of Mode2)
      Something like that....
      Any thoughts?
    • Ashish Khemka
      Hi Brett,
      If the deformations look to be in same direction then you can add them using the user defined results (as indicated above) or solution combination:
      Solution & Load Combination in ANSYS - Bing video
      Ashish Khemka
    • Brett D
      Hey thanks for that. I checked out the video, that isn't quite what I'm after.
      Could you explain how I would add the deformations? What is likely to be the case is one mode shape will deform one part of the structure and subsequent mode shapes will deform different parts. i want to combine them so I can export it as one STL
