February 21, 2022 at 5:52 pm
iqnlo
SubscriberHi there
I am doing mode convergence test for my own design of edge coupler. But I found that the mode didn't converged.
I'm using the codes from this page: Convergence testing process for EME simulations – Lumerical Support
First of all, I applied this script on your official edge coupler: Edge coupler – Lumerical Support
February 23, 2022 at 2:01 amKyle
It's possible that you're using too many modes, as discussed in this video: Convergence Testing - Too Many Modes. If you set the energy conservation to "none" and turn off the CVCS method, what does the convergence test look like?
March 15, 2022 at 3:05 pmMarch 15, 2022 at 3:08 pmiqnlo
SubscriberIn the tutorial, I remember that using CVCS is always recommended for the taper shaper structures. There should only be slight difference between the "none"and "CVCS" because of the staircase effect.
But in my case, 50% loss in included when I change the CVCS to none
- Error on Lumerical device
2524
2066
1279
1096
457
