January 15, 2023 at 6:26 am
Chris Chase
SubscriberI want to launch a gaussian source from air to be incident on a freely suspended grating, and calculate overlap between reflection and launched gaussian source. I guess I need to use mode expansion monitor. How should I pick mode selection?
January 16, 2023 at 5:53 pm
Guilin Sun
Ansys EmployeeUnfortunately, mode expansion monitor only works for waveguides. In your case, you will need to calculate the overlap with a monitor to get the reflection profile and the source fields after simulation. Please refer
https://optics.ansys.com/hc/en-us/articles/360034396834-Understanding-the-mode-overlap-calculation
https://courses.ansys.com/index.php/courses/lumerical-fde-solver-physics/lessons/overlap-and-frequency-sweep-lesson-2/
- Error on Lumerical device
2630
2110
1335
1110
461
