Photonics
Photonics
Mode solution not converging
    • Yuqi Meng
      I am simulating an MZI interferometer. I swept the reference arm length and am expecting to see the received intensity in the reference arm oscillating ina sinusoidal waveform. However, I encountered two problems.
      First: the simulation does not converge even with thick PML.(from the output movie seems like all the energy has already left the simulation domain bu as the simulation keeps running the auto shut-off level keeps increasing);
      Second: After I set a shorter simulation time to terminate the simulation after the light time when the light should have left the simulation domain. I get not a perfect sinusoidal wave but one with oscillations.
      I am attaching my simulation file as a google drive link here if anyone can help me out.
      Thank you!https://drive.google.com/drive/folders/10m6LFrfLq_L-2pW1t9jfkvlSSlNQQ8tJ?usp=sharing
    • Guilin Sun
      Unfortunately, Ansys does not allow employess to download customer files in this forum. If the problem still exists after modification with the following suggestions, please send us a support email if you have premium support privilege.
      When simulation seems to diverge, you will need to find the root cause: is it due to material fitting, dt factor or PML. You can modify the material fitting, use metal BCs and see if it still diverges, or increase the number of PML layers. The later is is important particularly if higher mesh accuracy is used.
      Please refer this post:
      Ansys Insight: FDTD varFDTD 常见的发散原因以及处理
      " shorter simulation time to terminate the simulation after the light time when the light should have left the simulation domain." is not recommended, since it may need longer simulation to reach autoshutoff min in order to get correct frequency-domain result.
      BTW: what quantity you use to check the result?  The sinusoidal result can only be observed through a time domain monitor, by choosing proper field component. The point time monitor should be located at the waveguide center, or where the amplitude is the maximum.
