February 1, 2023 at 10:00 pm
schinta3
SubscriberHello,
We have an HPC cluster with only headless nodes (no X11 forwarding). Is there any way to run MODE without the GUI, or process .lms files in any way?
Essentially we would like to use this methodology https://optics.ansys.com/hc/en-us/articles/1500006208582-Sweep-analysis-for-dispersion-calculations from command line.
February 2, 2023 at 5:27 pm
Lito Yap
Ansys Employee@schinta3,
You cannot run the Lumerical "script.lsf" on a headless cluster. Lumerical scripts require a GUI connection to run.
>>Lumerical product components and licensing overview – Ansys Optics
You can only run the "simulation_file.lms" directly from the terminal or on your cluster's job scheduler submission script.
>>Running simulations using terminal in Linux – Ansys Optics
The command line to run the "simulation.lms" file would be something like this: (default install path for 2023 R1 shown)
/opt/lumerical/v231/mpich2/nemesis/bin/mpiexec -n 4 /opt/lumerical/v231/bin/fd-engine -t 1 simulationfile.lms
/opt/lumerical/v231/mpich2/nemesis/bin/mpiexec -n 4 /opt/lumerical/v231/bin/eme-engine-mpich2nem -t 1 simulationfile.lms
/opt/lumerical/v231/mpich2/nemesis/bin/mpiexec -n 4 /opt/lumerical/v231/bin/varfdtd-engine-mpich2nem -t 1 simulationfile.lmsSee also the KB guide below on how to run sweeps without the CAD.
>>Running parameter sweeps without the CAD – Ansys Optics
Hope this helps.
- Error on Lumerical device
- Ansys Insight: Why my simulation result is different from published paper or experiment?
5364
3363
2471
1310
1020
