August 16, 2022 at 3:15 pm
gmartinezdearriba1
Subscriber -
August 16, 2022 at 4:56 pm
Guilin Sun
Ansys EmployeeFDTD uses FDE as the mode source solver, so there is no need to import data from FDE to FDTD. Thus its dataset format is not designed to do this. FDE dataset has no wavelength data but FDTD needs it. If you really want to import, please follow this example https://optics.ansys.com/hc/en-us/articles/360034383054-Using-an-equation-to-define-the-spatial-field-profile-of-a-source-in-FDTD
Basically you need the following script to create source data for import:
EM = rectilineardataset("EM fields",x,y,z);
EM.addparameter("lambda",c/f,"f",f);
EM.addattribute("E",Ex,Ey,Ez);
EM.addattribute("H",Hx,Hy,Hz);
E and H are 4 dimensional matrix, even if one (source normal direction such as z) or two (z and frequency) has only one value.
- Error on Lumerical device
- Ansys Insight: Why my simulation result is different from published paper or experiment?
5290
3311
2469
