Model Calibration a material curve from tensile testa
    • Tim Fricke
      Hey guys,
      I've been sitting at the pc for 3 days trying to reproduce the material curve from the tensile test with a material I created myself in Ansys. Unfortunately, I can't get it to work and I'm slowly getting desperate :D
      The model in Ansys works. I was also able to load the curve from the experimental test into the signal processing (see picture).
      I would now like to display various force-displacement curves in Optislang with a parameter study. So I can slowly approach the experimental curve.
      Unfortunately, I can't get other curves to be displayed in the signal plot apart from the test curve.
      What am I doing wrong or where is my mistake?
      Best regards
      Tim
    • Ashish Khemka
      Hi Tim,
      The stress-strain curve from analysis should be the same as the input material properties under engineering data. For a variation in load deflection curve are you modifying the material input as well?
      Ashish Khemka
    • Tim Fricke
      Hi Khemka,
      thanks for the answer. Yes i choose the nonlinear settings and the Gurson Model for the material failure. Like this below
      For the first step i set the Gurso Parameter constant to focu on the course in the plastic and elastic area.
      My goal is to get a signal plot like the picture below.
    • Tim Fricke
      i think i need to creat the right responses in the ETK application but i dont know how to get the right Signals and how to work with them. Maybe someone has an idea ?
Viewing 3 reply threads
