November 19, 2020 at 12:07 am
KRABBIT
SubscriberHi, I'm working in Discovery AIM in electromagnetism and I keep getting the error "Model dimensions (36057, 42544) are beyond the expected range (1e^-06, 10000).
My model is about 7 meters tall, so I'm not quite sure what these values are even coming from. Any and all help would be appreciated.
November 19, 2020 at 7:43 am
Charudatta Bandgar
Forum ModeratorHello KRABBIT ,
Are you using a student version for Discovery AIM? The model dimension limit could be due to the limitation of a student version, I will still confirm with the experts and get back to you with a concrete answer.
Regards.
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
8740
4658
3151
1678
1452
