October 23, 2018 at 3:07 pm
October 23, 2018 at 3:12 pm
Sandeep Medikonda
Ansys EmployeeDoes the solution output show a completed solution? Also, look at the force convergence plot if this is a non-linear analysis.
Also, please provide the version no. when you reply?
Sandeep -
October 23, 2018 at 3:19 pm
sameerfares
SubscriberHi Sandeep,
Its R19.2
How can you check if the solution output is a completed solution?
Where is the the force convergence plot? This is not a non-linear analysis.
Sam
October 23, 2018 at 3:25 pm
October 23, 2018 at 4:02 pm
October 23, 2018 at 4:04 pm
Sandeep Medikonda
Ansys EmployeeSo your simulation isn't running at all or there is nothing in the file you opened (you must have opened an Archive). Can you right click on Static Structural (A5) and clear generated data and try running it again? You should atleast see some warning or error messages.
Sandeep -
October 23, 2018 at 4:17 pm
sameerfares
SubscriberThat fixed it. what causes it?
Thank you Sandeep!
October 23, 2018 at 4:24 pm
Sandeep Medikonda
Ansys EmployeeIf you opened an archive file which was archived without results you will see a green check mark against it since the model completed fine on the computer it ran but it was just not packaged/archived with the results.
One quick check is to look at the solver output but also right-click on the Solution (A6), open the solver files directory and see if you have the file.rst there, this file contains the results.
Anyways, glad it worked.
Sandeep
2064
1279
1094
456
