Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
Model for computing S-Parameters for Mettallic Waveguides in HFSS
    • Hptrivedi
      Hi, I want to understand how HFSS Computes S - Parameters for Metallic Waveguides. Because the S11 shows a good match even for frequencies below cut-off, whereas the S21 shows that there is heavy attenuation for frequencies below the cut-off. Also, I want to understand  the model used in HFSS to compute the S-Parameter matrix for unnormalized (Do not Renormalize) Waveports. I can model the S parameters computed by HFSS for a metallic waveguide in another software for the waveports which are Renormalized to 50 Ohm (using port impedances computed by HFSS) and get a similar result as HFSS, but cannot model the unnormalized (Do not Renormalize) waveport.
      kindly help.
Viewing 0 reply threads
