Model heat exchanger
    • hugo CFD
      Hello
      I'm trying to use the heat exchanger model to calculate the heat. However, this warning appears  that causes the calculated heat to be 0 W. how does it overlap the fluid zones?
      Warning: primary zone 11 and auxiliary zone 10 are not overlapping for the heat exchanger hxc-1
      I know this command, mesh → modify-zones → copy-move-cell-zone, but it did not solve.
      regards
      Hugo
Viewing 0 reply threads
