March 19, 2023 at 6:27 am
din_hn
Subscriber 🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & ConditionsI am trying to prepare a geometry imported from SOLIDWORKS into ANSYS Spaceclaim then simulating it into ANSYS Fluent.
But seems like I got numeral problems. Firstly, I imported the a .sldprt into spaceclaim and made an enclosure, then going to fluent, but it couldn't mesh the blades properly so it disappears.
Then, I tried to import a .stl into spaceclaim instead, I first tried without using an enclosure and meshed the turbine and it worked perfectly but when I tried to add an enclosure to the turbine, it keeps saying, "An error occured while creating the enclosure (empty body). Try increasing your cushion value." I kept increasing it till 1000% which is already nonsensical to do an enclosure that big and it still doesn't work. I tried to use the repair tools in spaceclaim to automatically fix the problem areas to the best that spaceclaim can but nothing works. Can someone help me?
I attached an image saying that an enclosure cannot be created. Then, I attached the spaceclaim, solidworks, and stl files of the turbine.
March 20, 2023 at 1:21 am
Charudatta Bandgar
Forum ModeratorHello Nurdhiyauddin Haji Nudin
Let me look into this.
Regards.
- pcb
- No longer possible to import f3d with 2023?
- line bodies and surface body shared topology
- How to chang unit in Ansys Discovery 2023?
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- SpaceClaim Script: Selection by FilterByBoundingBox
- Assignment of revolute joint
- Max/min over time results in AIM
- Axisymmetric model – Rubber seal
- To change language in Ansys Discovery
8808
4658
3153
1680
1470
