Systems
Systems
Model requires more scratch space than available.
    • Manoj55
      RAM is 64GB
      Hard disk space available is 200GB
    • peteroznewman
      Double the RAM on the computer (if you can afford it and if the motherboard supports it).
      Reduce the number of nodes and elements in your model.  Can you use symmetry?
    • Manoj55
      I am not using symmetry. Reducing number of nodes doesn't working.
    • peteroznewman
      You need to provide more information if you want help on this. There is always a way to simplify a model to fit within the available resources.
Viewing 3 reply threads
