Modeling a Galvanic Cell with a specified electrolyte solution
    • yalweqay
      How can one go around in modeling the chemical reactions of a galvanic cell? are there available models that I can use to perform such simulations? So far, I've looked into the PEMFC model and found that the chemical reactions are specified. I am trying to simulate the chemical reaction of copper electrodes with copper sulfate electrolyte solution.
      Thank you
      There are some electro chemical options with the battery module, but you may be fine with a surface reaction.
    • yalweqay
      Thank you for your message, will the surface reaction option able to handle reduction and oxidation reactions?
