Preprocessing
Preprocessing
modeling and meshing
    • santrondela
      The surface mesh is intersecting or close to intersecting, making it difficult to create a volume mesh. Please adjust the mesh size or adjust the geometry to fix the problem.
    • Aniket
      This error usually occurs when you have non-manifold geometries in the model. (or very thin bodies paired with large mesh).
      right-click on the error message and show problematic geometry. If it doesn't manually inspect for nonmanifold and thin bodies in your model.
      Also please post in a correct category (I am moving this thread to Mesh Generation).
      -Aniket
    • santrondela
      Thank you Mr. Aniket
      Is there any way by which i can reduce the meshing time.
    • Aniket
      The only way for that is to use coarser mesh. Also, you can go and mesh the bodies individually so that you get an idea of problematic body instead of meshing the entire model at once.
    • Keyur Kanade
      Please go through some meshing tutorials and help document.
      Keyur
Viewing 4 reply threads
