July 17, 2018 at 12:26 am
joepa_2017
SubscriberI am attempting to create a mesh using an image. I want to segment the image and then create the mesh. I would either segment the image and then import the geometry into APDL or segment and mesh the image and then import the mesh into APDL. Does anyone know of a program that could help me do this?
July 17, 2018 at 1:05 am
SubscriberPlease attach the image.
July 17, 2018 at 4:04 am
Naresh Patre
Ansys EmployeeYou can import the image in SpaceClaim and then create a geometry using reference of that image. Once the geometry is created, you can then mesh it in Workbench meshing application.
July 17, 2018 at 5:04 pm
joepa_2017
SubscriberThank you @nmpatre! Importing the image in SpaceClaim sounds promising. I am not seeing an Insert button on SCDM 19.1 however. From what I've read online, there should be an Insert button in order at the top of the GUI. Has this changed for the new version? (I am quite new to SpaceClaim FYI)
July 18, 2018 at 7:35 am
Naresh Patre
Ansys EmployeeHello joepa_2017,
The tools have been reorganized in the latest versions. You can find the File option under Assembly tab through which you can insert images.
Also, check out below YouTube videos on image insertion and vectorizing images in SpaceClaim:
2080
1315
1108
459
