Modeling effective pressure hermeticity
    • john.x.juveli
      Hello all,
      I am shooting a laser beam via radiation on a weld joint and correspondingly trying to understand the gas pressure in the air cavity and it's effect on the neighboring solder material.
      If you include a gap (including porous media) then air will leak. Modelling the gap will require far too much mesh, so isn't a good idea. Do you know how much air is leaking?
    • john.x.juveli
      we do not, and that is what we would like to try to characterize. Is there a more preferred approach to emulate an imperfect seal on a perfect model geometry to more closely mimic reality?
      In most cases we assume zero leakage. If you run like that what's the maximum pressure you see in the air space?
Viewing 3 reply threads
