Modeling electrical conductivity as a function of electrical resistance
    • Luis Pusey-Alvarado
      Hi every body :
      Hoping that everything is going well.
      i need urgent help please.
      -the electrical conductivity in my problem is not constant, it changes with electric resistance, and this electric resistance changes with temperature.
      the electric resistance in my problem is given by 𝑅=𝑅_0 (1+𝛼(π‘‡βˆ’π‘‡_0)) where T_0 is 20C and T is static temperature of the wire. and R_0 is 11Ohm.
      how can I write an expression to incorporate this resistance into the conductivity for aluminum in fluent. thanks
    • Murari Iyengar
      Hi, Under Electrical Conductivity options, you can select Expression and then input the expression as required.
