December 13, 2022 at 5:44 am
neda_e
SubscriberHi,
I'm trying to model heat pipes using thermal network in Icepak AEDT.
There is a heat pipes macro availble in Icepak classic, which is using the thermal network. I tried to recreate the same in Icepak AEDT but struggling with the setup of the thermal network.
Do you have any suggestion?
Thanks
December 16, 2022 at 8:08 am
Anchal Singh
Ansys EmployeeHello Neda_e,
Heat pipes macro is not available in AEDT Icepak 2022R2. You may contact regular support through the customer portal by raising a service request.
Regards
Anchal
- Maxwell, HFSS or Q3D?
- Error
2688
2130
1349
1136
461
