February 3, 2021 at 6:46 pm
mattsarg555
SubscriberHey all,nI have used ANSYS quite a bit in the past but I am new to HFSS. I am currently trying to see if it is possible to simulate a change in refractive index within a waveguide under some thermal application. I am not sure how I should go about doing this so any guidance would be much appreciated.nn -
February 8, 2021 at 1:23 pm
rtk
Ansys Employee,nCould you please more specific on the need? Mainly, about the refractive index incorporation within a waveguide and the end goal.nThis way we could help you better.nThanks
- Maxwell, HFSS or Q3D?
- Error
5268
3299
2469
