June 17, 2019 at 4:54 am
Doba
SubscriberI want to simulate a material expanding/shrinking under constant fluid flow (whose rate can be changed). I am assuming this needs to be done using System Coupling (2 way FSI) but I am not sure how to model expansion and absorption
I watched these 2 videos about 2-way FSI
June 17, 2019 at 5:13 am
DrAmine
Ansys EmployeeRegarding the fluid part which fluids and states are included? -
June 17, 2019 at 5:53 am
Doba
SubscriberRegarding the fluid part which fluids and states are included?
The material is Chitosan (hydrogel) and the fluid is humid air (lets say 50% RH)
June 17, 2019 at 7:38 am
DrAmine
Ansys Employeeand the absorption is described through what? Mass flow Inlet?
June 17, 2019 at 9:48 am
Doba
I believe so, yes.
I'll be remaking the geometry shown here - https://forum.ansys.com/forums/topic/some-of-the-residuals-increasing-sharply-after-20-or-so-iterations/
July 3, 2019 at 5:29 am
Doba
SubscriberBUMP
Anyone?
July 3, 2019 at 2:46 pm
Ansys EmployeeIf there's no need to calculate the forces on the solid bits have a look at moving deforming mesh: you can move a surface based on whatever criterion you desire.
3744
2573
1809
1236
594
