Modelling Heat Flow in soil using Ansys Fluent
    • vsjay3
      Hi Everyone,
      As part of my research I'm using Ansys Fluent to model :
      1) Heat flow through compacted soil (clay) with an embedded ground heat exchanger
      2) Heat flow through compacted soil (clay) without an embedded ground heat exchanger
      For both above cases I simply need to obtain the resulting temperature contours. I would only be modelling heat flow through the soil medium and not water flow.  Water flow will only occur inside the ground heat exchange pipe.
      I am new to Ansys Fluent and apologize if this is a very basic question:
      Now, I have the required properties of the compacted soil (Density, thermal conductivity etc.) but I'm not sure if to model the compacted soil medium in Fluent as a "Porous" medium or simply a "Solid" medium.
      I've read some papers on similar modelling approaches but I could not find a clear answer to this.
      Hence, any advice on the above matter would be much appreciated.Thank you!
Viewing 0 reply threads
