Modelling hinge joint for Six DOF solver
    • suyogmahulkar
      Dear sir,
      I need to perform computation using Six DOF solver. There are two 2D rigid solid bodies in quiescent water domain, having hinge joint in between them. Bodies are free to move in the fluid domain; the only constraint is hinge joint between them. When the force has been applied on the terminal of one of the body, I need to compute trajectory of another body along with pressure & velocity field .  Basic issue is to model a re-volute joint.
      So, I request you to give some suggestion regarding the same.
Viewing 0 reply threads
