modelling hyperelastic models
    • trayC
      I am basically trying to model two hyper-elastic bodies, a ball squeezing out of a cylinder. But I keep getting an error which states that a solution could not be found at some points in my model.
      I was wondering if anyone had any tips regarding how to solve this issue?
      I already changed my settings to have large deflection turned on.
    • peteroznewman
      Is this a multi-step Static Structural model?
      Is the ball inside the cylinder at the beginning and contact resolves the initial penetration?
      How are you getting the ball to move to the end of the cylinder?
      There comes a time when the force the cylinder exerts on the ball propels the ball dynamically out of the cylinder.
      You can see that in a Transient Structural model, but there is no static equilibrium past that time.
      I can be more helpful if you attach your project archive to your reply. Use File, Archive... to create a .wbpz file that you can attach if it is < 120 MB.
    • trayC
      Hi! thank you so much for replying
      I am actually trying to model a very simplified version of the process of childbirth, whereas the "ball shape" in the middle is the baby and the cylinder outside is the uterus.
      I am trying to squeeze the baby out by applying a pressure around the uterus. At the moment it is just one step - applying a single pressure to the mode but I keep getting the error " the solver engine was unable to converge on a solution for the nonlinear problem as constrained".
      I appreciate any advice you have !
    • peteroznewman
      Hi trayC,
      This sounds like an interesting and challenging model.
      To get started, I recommend you attempt to get a 1/4 model running. By using two planes of symmetry, and one Y=0 Displacement BC on the flat face at the cervix, the model is fixed without using a fixed support. This will allow the cervix to dilate as the head moves forward.
      I made those changes to your model, but I had to make two new revolves in DM to clean up the geometry for meshing. What CAD system are you using?
      You have initial interference between the baby and the uterus, so you want at least a 2 step solution. Step 1 has no pressure, and is used to resolve the interference in the contact. If that is successful, step 2 will apply pressure.
      How much interference did you want to stretch the uterus? It is difficult to get the contact to resolve the large overlap, so another method is to create the geometry so the baby is just touching the uterus wall. A thermal expansion coefficient is included in the fetus material model so a temperature increase will "grow" the baby to the interference you wanted. Now this is a 3 step model. Step 1, resolve contact, Step 2, grow the baby using temperature, Step 3, apply Pressure.
      You need a minimum of 3 elements through the thickness of the uterus wall. Are you limited to the Student license or do you have access to a Research license? It is a challenge to stay below the 32k limit of nodes+elements in the Student license. The attached ANSYS 18.2 archive model does that and is able to move the baby along by pressure for some distance before failing to converge.
      https://youtu.be/1bJzqPVe4j0
      Why does it fail to converge?
      Newton-Raphson Residual plots are saved to show why the solver could not find an equilibrium beyond this load increment.
      This plot shows where a mesh refinement will help the solver to converge. Below is a finer mesh that was able to converge on the next pressure level.
      Unfortunately, we are already at the limit for the Student license. The next step is to take this model to a fully axisymmetric model and use a 2D slice to represent the 3D object. The 2D bodies have to be around the Y axis for this type of model and you have to select 2D on the Geometry properties before you start drawing. Unless you are on a Research license, then you can stay in 3D.
    • trayC
      Hello! Answering your questions
      What CAD system are you using? SolidWorks 2016 x64 edition
      How much interference did you want to stretch the uterus? just enough to allow the passage of the baby
      Are you limited to the Student license or do you have access to a Research license? I have a research license but only with Ansys 18.0
      I shall follow your advice and try to perform the next few steps of creating axisymmetric model and increase mesh density !
Viewing 4 reply threads
