TAGGED: absorption, lumerical, nanoparticles, plasmonics, scattering
August 6, 2023 at 6:28 am
Debasish Biswasray
SubscriberHi,
I am trying to model an array of metal nanoparticles to find the extinction cross-section (absorption + scattering cross-sections). I have taken a large number of nanoparticles in the FDTD cell and calculated the extinction section spectra. In order to modify the extinction cross-section, I always have to change position and size of the nanoparticles. To get the desired extinction cross-section spectra (increased the FWHM), I have to follow a trail-and-error method like this. I change the size and position of some of the nanoparticles and check the spectrum.
I want to know what are the parameters that can be changed to increse the FWHM of the extinction cross-section spectra.
Also, is there any method to change the size and position of the nanoparticles with a few parameters, not by changing them for individual nanoparticles?
Thank you, in advance.
Debasish
August 6, 2023 at 4:17 pm
Devika Padmakumar Nair
Ansys EmployeeHello,
You can try using parameter sweep ( Parameter sweeps, Optimization and Monte Carlo analysis overview – Ansys Optics ).
Training material available here : Running a Simulation Using Ansys Lumerical Scripting — Lesson 1 - ANSYS Innovation Courses.
In this case can set "the size and position" as parameters to optimize and find the optimum value.
Thanks
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7658
4476
2957
1433
1322
