July 18, 2023 at 8:39 pm
Musa Kamil Öztürk
SubscriberHello,
I am trying to model the rigid polymeric foams. Considering the mechanical properties of rigid foam, which material model would make more sense to use? Mooney-Rivlin, Ogden, Blatz-Ko, Hyperfoam etc.
July 20, 2023 at 1:10 pm
Tasos Zacharakis
Ansys EmployeeHello Musa,
If the material is known to be incompressible by nature, it is preferred to use Moonley-Rivlin, Yeoh, Ogden etc.
If the material is known to be compressible, it is preferred to use Ogden-foam, Blatz-ko etc.
You can also advise this course Energy Functional | Ansys Innovation Courses.
Thank you,
Tasos
August 17, 2023 at 7:49 am
Anushika Wijerathna
SubscriberDo you have any idea about how to model a shear thickening material like a oobleck material
in ansys workbench
August 17, 2023 at 2:50 pm
Tasos Zacharakis
Ansys EmployeeHello Anushika,
Please start a new post with your question.
Tasos
- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- How to add SN curve for new material in Fatigue analysis?
- ANSYS 19.0 with Additive Manufacturing Extension
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- About Bilinear Isotropic Hardening Plastic Model !
7742
4502
2961
1449
1322
