February 10, 2021 at 11:03 am
akban
SubscriberHi,
I want to simulate open channel flows where flow velocity and waves on interface co-exist.
My 2D geometry is shown here:
February 10, 2021 at 1:17 pmRob
Ansys EmployeeThe surface Free surface needs to be away from the water free surface and set as a pressure boundary but not part of the open channel. Open channel is for where the waves enter and leave the domain.nFebruary 10, 2021 at 1:36 pmakban
SubscriberDear sir,nI did what you suggest. The free surface in my image is at z=0.5 m and water free surface is at z=0.2 m. Please check pressure outlet boundary condition.nFebruary 10, 2021 at 1:46 pmRob
Ansys EmployeeWhat is pressure outlet set as? You need more spare height and if the domain is only a few metres long you may want to consider how big the waves should be and what the model was designed for. nFebruary 10, 2021 at 2:27 pmakban
SubscriberThe pressure outlet is se as pressure outlet. The domain dimension: length, L=5 m, water depth, d=0.2 m, domain height, H=0.5 m. Velocity of water, v=0.2 m/s.nnPlease suggest.nFebruary 10, 2021 at 3:11 pmRob
Ansys EmployeeI'd make the height enough that the waves aren't anywhere near the top of the domain. With a shallow depth you'll need to choose the wave conditions carefully, you also need more mesh in the domain to track the free surface. nFebruary 10, 2021 at 3:24 pmakban
SubscriberThanks.nFew points:nI provided a wave of zero amplitude to check if I get water flow velocity contour properly. I thought upon getting that, I would introduce waves of non-zero amplitude for future simulations. But the velocity contour came to be weird -- my main issue is with simulating the water flow.nIf my way of producing open channel flow (without wave) is wrong, please suggest the better way.nnRegards,nAyannFebruary 10, 2021 at 4:26 pmRob
Ansys EmployeeDid you patch in the water? We do use the model without waves regularly for various applications. nFebruary 10, 2021 at 7:57 pmakban
SubscriberHi,nnI did try patching the water. Even with this my velocity came to be unreal. nFor example, I used only open channel option (leaving open channel wave BC) :nI used water density as compressible:n
I did patch the domain of water. nBoundary conditions:nInlet- velocity inlet, noutlet & top of the domain- pressure outletnbottom- wallnnThe solution I got after 24 seconds is:n
Please suggest.nn
February 10, 2021 at 10:17 pmYasserSelima
SubscriberYou can ignore the compresability of water ... I am not sure is your inlet 0.5 m height or 0.2 m height (Whole domain height, or just water height)nSecond with the dimension you mention and the mesh on the first post, you will not get the free surface. You need fine mesh around the interface ...nFinally, if you simulated 24 seconds between your comments ... you are using a super super fast HPC or you are using very large time step. And most probably you don't do enough iterations to convergenFebruary 10, 2021 at 11:24 pmFebruary 10, 2021 at 11:59 pmYasserSelima
SubscriberI think you should have the inlet velocity inlet of a height of 0.2 m, not 0.5 m. If you keep it 0.5 m, you will have flow rate more than you want. Also. it might be source of instability of the free surface.nFebruary 11, 2021 at 12:08 amakban
SubscriberHi,nI tried to do so. In that case, the problem is what condition should I use for top 0.3 m? If I use pressure inlet for top 0.3 m, then it takes secondary phase by default. That's the problem.nFebruary 11, 2021 at 12:57 amYasserSelima
SubscriberYou are right, It should take the secondary phase. But you should check the open channel wave BC to be able to put the free surface at the inletnFebruary 11, 2021 at 1:01 amakban
SubscriberBut if it takes secondary phase in the top 0.3 m, where secondary phase (water) does not exist, won't it give wrong results? nFebruary 11, 2021 at 1:12 amYasserSelima
SubscriberNo, it will take airnFebruary 11, 2021 at 1:15 amakban
SubscriberThanks. I will try and inform again.nnRegards,nAyannFebruary 11, 2021 at 1:19 amakban
SubscriberOne point:nI am using velocity inlet in the water inlet. I have clicked open channel wave BC & Segregated velocity inputs, where I have provided velocity for the incoming water. Primary phase has no velocity. Please refer the image in the first message. Is it okay ?.February 11, 2021 at 9:43 amakban
SubscriberHi,nIf I use height of 0.2 m to be the inlet, then the problem is what condition should I use for top 0.3 m ? If I take pressure inlet, it takes secondary phase by default.nThat's the problem.nnFebruary 11, 2021 at 12:00 pmRob
Ansys EmployeeIf you pick waves then the velocity boundary gives nnSo you specify inlet velocity for both phases. Note, you need sufficient resolution to do this. If you don't have waves we'd tend to use a velocity inlet for the water & pressure for air that's above it. n
February 16, 2021 at 2:39 pmakban
SubscriberHi,nI have followed all the suggestions.nMy domain height is 0.5 m, water height is 0.2 m. I have two inlets- one water inlet , and another is air inlet. Water flows in the channel and air remains stationary. I am using velocity inlet for the water & pressure inlet for air that's above it. I am using open channel wave BC option along with segregated velocity input (water velocity -0.15 m/s, air vel- 0 m/s).nMy resolution is high, time step is 0.001 (initially) and 0.01 later on.nBut velocity contour is not acceptable.nKindly suggest.nnRegards,nAya
February 16, 2021 at 4:17 pmRob
Ansys EmployeeIs it converged, and is the mesh resolution sufficient? nFebruary 16, 2021 at 4:31 pmakban
SubscriberYes, it is converged and the resolution is pretty highnFebruary 16, 2021 at 4:53 pmRob
Ansys EmployeePictures pleasenFebruary 16, 2021 at 5:26 pmFebruary 17, 2021 at 4:08 pmRob
Ansys EmployeeAnd convergence? nFebruary 17, 2021 at 5:01 pmakban
SubscriberSimulation did converge at every step.nI ran in transient. nViewing 26 reply threads- You must be logged in to reply to this topic.
5364
3351
2471
1310
1018
