Modelling sandwich structures in ACP
    • Venugopalb
      Greetings to all,
      I am working on buckling analysis of composite sandwich structures. If we have only composite, we can give ply orientation, thickness to model the composite. But, if we want to model sandwich structure, how can we add core material in between composites?
    • naeem
      1. There are predefined core materials (foam core like SAN etc & honeycomb can also be modeled) in ansys composite material library.
      2. If you want to define your own foam core like PU( which isn't available in earlier versions of ansys) you need to add "ply type" property, among all other properties. You can define  " Homogeneous foam core" as ply type.
      3. simply create fabric of foam core with required thickness in ansys ACP.
      4. Apply same rules of Rosette and oriented element set etc. direction wont affect because its a homogeneous material.
      5. In the end create solid model.
    • Venugopalb
      Thabk you very much for response.
      I will try it and let u to know.
