Preprocessing
Preprocessing
Topics relate to geometry, meshing, and CAD
Modelling V-Shaped cutouts in ACP Solid Model
    • Sankar Suresh
      I'm currently performing a Modal Analysis of a Circular Disc, with a cut on it (V-shaped with certain depth to it). I modelled my composite using ACP, and ran an analysis of the completed disc in Modal, and got good results. I would like to do the same with the cut. But, I'm unsure of how to create the cut, considering the fact that the Geometry prepared before ACP is Surface, and cannot be altered later on after it converts to solid after ACP.
      Thanks in advance!
    • Reno Genest
      Hello Sankar,
      You may be able to create the V cut-outs using extrusion guides when doing the solid extrusion:
      You can also import geometries to use as cut-outs:
      You will find more information in the ACP help:
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v231/en/acp_ug/acp_solid-model.html
      If you have access to the Ansys Learning Hub, you will find more information in the ACP training course:
      https://jam8.sapjam.com/groups/YHNivy2FbzTCwBmZhqlMGS/overview_page/X59hQ2TTw5kCamrfUyAeA6
      Let me know how it goes.
      Reno.
    • Reno Genest
      Hello Sankar,
      An alternative is to build the composite layup on a surface like you have been doing, but instead of extruding the solid model, you can import a solid mesh of the finished part (with cut-outs and everything) and then map the composite layup on the solid mesh. You will find more information about this technique along with an example model in the help:
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v231/en/acp_ug/acp_ex_mapped_composite_solid.html
      Reno.
    • Reno Genest
      Hello Sankar,
      The WB workflow to map the composite layup directly on an existing solid mesh can look as follows:
      Reno.
    • Sankar Suresh
      Thanks a lot Reno! Will try it out and let you know.
    • Reno Genest
      Hello Sankar,
      Sounds good. You can import CAD to use in the solid extrusion as guides or cut-offs as follows:
      Reno.
Viewing 5 reply threads
