February 17, 2023 at 5:57 am
Soikot Sarkar
SubscriberHow can I calculate the total number of modes that exist in a photonic crystal cavity as well as their frequency? I need it for laser simulation.
February 17, 2023 at 6:31 pm
Guilin Sun
Ansys Employee"total number" would be tough as we do not know the operating frequency range.
But you can simulate them with specified freqeuncy range, and use more randomized dipole sources so they can exite all the modes the cavity supports. You may also add a few different analysis groups in different locaitons, each has a few monitors. This is better than to have one analysis group with many time monitors, I personally believe. Please refer the example: Photonic crystal cavity
- Error on Lumerical device
3850
2609
1853
1246
600
