June 17, 2022 at 9:18 am
June 20, 2022 at 12:49 pm
Ashish Khemka
Ansys EmployeeHi,
Try editing the geometry in SpaceClaim. You cannot edit the geometry in Mechanical.
Ashish Khemka
June 20, 2022 at 3:06 pm
Mike Rife
Ansys EmployeeHi @georgesbrivaelb See the Mechanical Help on "Virtual Topology". We can't change the shape i.e. cut the body into two bodies. But we can cut faces on the body (Virtual Split Face) by two vertices. So if you need to split that face only for meshing or loading, then VT may be the way to go.
Mike
p.s. right-click the Model object and VT should be a choice to insert to the tree.
3744
2573
1821
1236
594
