September 3, 2019 at 8:31 am
Oelot
SubscriberHi !
I imported an extern model ( a keyword file (.k) from LS-DYNA, it gave me a mechanical model, but I have the impression the size are wrong.
I want to give the right size, but I can't access to geometry model ( it was not create ? )
Could you help me
Thanks
September 3, 2019 at 9:01 am
Ansys EmployeeDo you mean a dimension is wrong or the whole model scale?
September 3, 2019 at 11:45 am
September 3, 2019 at 12:41 pm
Ansys EmployeeDid you read the model straight into Mechanical or through SpaceClaim? If the latter check the dimensions and whether the units are confused. A factor of 50 is odd, a factor of around 25 usually means you've got inches and metres messed up. You can scale in SpaceClaim.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2564
2080
1299
1106
459
