April 27, 2023 at 9:43 am
Plebian Seth Tamba
SubscriberGood day, I am currently doing an analysis on a Reinforced concrete column. I want to do a fatigue analysis but the error "An error occured inside the Fatigue module: Invalid or missing stress life curve" always show. Other forms of analysis does not have an error. The the property for steel reinforcement already has a S-N cruve.
May 2, 2023 at 3:26 am
Ashish Khemka
Ansys EmployeeHi,
Please see if the following link helps: Invalid/missing Stress Life curve (ansys.com)
Ashish Khemka
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5028
3137
2377
1306
922
