November 7, 2019 at 8:51 pm
jehanzeb
SubscriberHello,
I am trying to add a force and moment reaction probe result in ansys Mechanical for contact region but it shows ? in the tree
whether for boundary condition fixed support its ok and solve but when i choose contact region its not working showing ? mark in tree
following the same method as explain
https://www.padtinc.com/blog/using-probes-to-obtain-contact-forces-in-ansys-mechanical/
but its not working for my case whats the possible reason and how i obtain moment and force reaction for contact region ?? please
Thank you!
November 8, 2019 at 5:17 pm
SubscriberDid you turn on Contact Miscellaneous under the Output Controls of the Analysis Settings?
Contact Miscellaneous. Turn On if Contact Based Force Reactions are desired. The default value is No. Available for Static and Transient Structural analysis types. Not Available when linked to a Modal analysis.
November 11, 2019 at 9:47 am
jehanzeb
Subscribernot working, After Contact Miscellaneous. Turn On
possible reason please
November 11, 2019 at 1:10 pm
SubscriberClick Solve and read any messages that get written out to the message window.
October 8, 2020 at 4:37 pm
EricRenner
SubscriberI had to turn on nodal forces and contact miscellaneous to get the force and moment reactions n
3299
2469
