May 25, 2023 at 8:02 am
Abdelmadjid Belmokhtar
SubscriberMomentum Residuals do not get under e-3 in a simulation of a cylone air filter with tangential inlet with sst turbulence model. What can be the problem? I tried different mesh nodes number and the results are the same.
May 25, 2023 at 11:10 am
Ansys EmployeeWhat do the monitor points tell you? Note POINT not surface.
May 26, 2023 at 10:49 pm
SubscriberThank you Rob for your reply. I forget to mention that I am runing a steady state simulation, and for the monitor points I made one point to monitor the velocity components in terms of accumulated time step and it shows somthing like a sinusoidal function for the three components of velocity
5162
3275
2451
