momentum source term
    • Dino
      When defining a mass source term through a UDF, we should also define momentum and energy sources. Here is the formula for the momentum source term, my question is, if the problem is axisymmetric, this formula would remain the same?
      Thank you,
      http://www.afs.enea.it/project/neptunius/docs/fluent/html/ug/node235.htm
Viewing 0 reply threads
