Monitor CH species in premixed combustion
    • krany3
      I'm using detailed chemistry in lean premixed combustion. But, Fluent doesn't show CH species in the solution. Is it because of the lean conditions?
    • DrAmine
      Which model are you using?
    • krany3
      I'm using flamelet generated manifold with GRI-mech 3.0
      Does the mechanism contain that species?
    • krany3
      Yes, it has the species
      If you list available species in the post-processing is there an option to pick it?  If the concentration is tiny (possible depending on the kinetics) you may need to review the colour map scale if you've altered the settings.
Viewing 5 reply threads
