Photonics
Photonics
Monitor reflection on the propagation path
    • ouyangxin
      Hello there,
      I am trying to simulate the coupling between different devices using FDTD. Refer to the official example, I placed a similar monitor in the entire simulation area.
      Facet reflection and transmission calculations https://support.lumerical.com/hc/en-us/articles/360042304894
    • Greg Baethge
      Hi Xin You are correct, the monitor records the fields at its location, so it will be the combination of the fields propagating (incident and reflected). It is not possible to separate both contributions, unfortunately.
    • ouyangxin
      Hi Greg,
      Thank you so much for your answers. That helps me a lot.
