March 17, 2022 at 5:32 pm
angie07
SubscriberHello all,
I am working on a simulation where air enters a tee pipe and exits through two slits. I have experimental data of the velocity field at the outlets from a hot-wire anemometer. I have attached a picture of my results from fluent post-processing and what a typical velocity field from a hot-wire looks like.
I want to monitor the velocity field in ANSYS and create a similar diagram in order to compare the simulation results to the experimental ones. How do I go about that?
Simulation results:
March 18, 2022 at 9:55 amRob
Ansys EmployeeI'd question whether the CFD images are of a converged or accurate solution, but leaving that to the side. In Fluent have a look in the Results/Display section at Vectors, Contours and Mesh . Create objects and then a Scene of the contour, vectors and mesh.
2600
2086
1317
1108
459
