November 16, 2023 at 9:31 am
Sungmin Yoon
SubscriberHello,
Currently I'm trying to observe time-dependent characteristics of charge diffusion(especially n & p attributes in acharge monitor), under pulsed voltage.
If electrical factor is the only stimulus to the object, is it okay to turn 'gloabl source shutter' to 'none', in charge solver edit window?
Thanks,
Sungmin
November 20, 2023 at 2:39 pm
Niki Papachristou
Ansys EmployeeHi Sungmin,
Thank you reaching out to us! I believe for your case you are correct you don't need the shutter and you can disable it. You just need to make sure the contacts in boundary conditions are changed accordingly vs time (V vs t). You should be able to see the evolution of n and p as the results are reported separately for each voltage.
I hope that was helpful, let me know if I can be of further assistance.
Kind Regards,
Niki
- Ansys Insight: Why my simulation result is different from published paper or experiment?
- Ganhemt Project mistake can you help me
- How to calculate the cross-polarization efficiency and phase in FDTD
- save data error
- Simulation of a single pillar of a peltier cooler
- EME : field profile and cell periodicity
- Ansys Insight: Single frequency CW source
- What is the meaning of this error ” Bad termination of…” ?
8808
4658
3153
1680
1470
