3D Design
3D Design
Topics related to Ansys Discovery and Ansys SpaceClaim.
Monitors not showing any values
    • nils jonsson
      Hello!
      When I try to simulate the monitors they show up completely empty. The message I get is "select one or more faces on a wall location". What does this mean and how to I solve it? I want to see the force on different parts.
    • Devendra Badgujar
      Forum Moderator
      Hello nils jonsson
      If you are doing a fluid simulation, the selected face needs to be defined as a Wall/inlet/outlet. Can you please check if the highlighted face is defined as a Wall?
      Also, you can refer the quick tip tutorials on how to monitor results and define monitors on construction geometry from this location below:
      Quick Tips - Viewing Results - Quick Tips - Ansys Discovery Forum
      Let me know if this helps.
      Regards.
