May 21, 2023 at 11:19 am
Marius Carrier
SubscriberHello,
When I display my contours, a lot of it has the same color, but when I enable lines, it shows me exactly where the pressure changes. What do I need to do so that the color changes with every pressure change, so that I get finer contours?
Thank you for your help.
Regards. -
May 22, 2023 at 9:34 am
Hemant Gurav
SubscriberHello ,
You can follow the methods mentioned here to display the Pressure contours distinctively.- From Contour window, hit compute and check for the pressure range, unselect the global range , auto range option and check clip to range option . Set the minimum and maximum pressure values as per your requirement .
- Click on colormap option in contours panel and change the settings according to your requirement , also you can set coloring option to banded or smooth to check which looks better
To know more about these options please check Customizing the Graphics Display (ansys.com)
If you are not able to access the link, refer to this forum discussion: How to access the ANSYS Online Help
5368
3363
2471
1310
1020
