Tagged: ansys-fluent, boundary-conditions, cfd, heat-transfer, mesh
March 5, 2022 at 3:51 pm
Sliceee123
SubscriberHello all
I am doing CFD simulation for air humidification , I am giving inlet air has 25 deg Celsius and relative humidity of 35% as there are no options for giving relative humidity as a boundary condition so I converted that relative humidity into mass fraction at inlet . But after the solution got converged when I am viewing the relative humidity at inlet it is showing 140% but the correct mass fraction is shown , and at the outlet the humidity is around 1500% , very high mass fraction of water vapor , how to deal with such cases please help .
March 7, 2022 at 5:04 pmRob
Ansys EmployeeCheck the boundary conditions, the easiest way is to initialise the model at the inlet conditions so you can confirm you got the RH to mass fraction conversion correct. As Fluent doesn't automatically turn on a condensation model it's common to see high RH values in some models, but 1500% is somewhat higher than I'd expect.
2524
2066
1279
1096
459
