October 8, 2022 at 1:56 am
October 10, 2022 at 2:49 am
Charudatta Bandgar
Forum ModeratorHello sen li
We do not have any models on our end, which product will you be using to do the further simulation?
Regards.
October 10, 2022 at 3:21 am
sen li
a controller for electric steering. there are some MOSFETs which drive the motor.
October 10, 2022 at 3:31 am
Charudatta Bandgar
Forum Moderatorsen li If you are not using Discovery products for the post processing on your case, you can post it on ANSYS Customer Portal or Ansys Learning Forum based on the type of license that you have. There you might find CAD models of MOSFET, etc. If you are just looking for a CAD model, we do not have any on our end. I will still check with the team and get back to you.
Regards.
October 10, 2022 at 4:42 am
sen li
thanks.
i'm using catia for building 3D model.
i've teared down some mosfet. i'll try by myself firstly.
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
8740
4658
3151
1678
1452
