3D Design
3D Design
Motion Band.
    • Supratap
      I have 3 parallel beams moving. Should I assign different motion bands to each of them. If yes, then is it possible to assign more than 1 motion band as In my ansys 2019R2 it is not allowing to do sonn
    • peteroznewman
      What is a motion band?n
    • Supratap
      The band in which you assign motion.nn
    • peteroznewman
      That doesn't explain it well enough for me to help you.n
    • Supratap
      It is the band in which we assign the mechanical transients, Like speed, direction of motion, limits of motion, mass, damping, load thrust, etc.n
    • peteroznewman
      Please insert an image to illustrate the band.n
Viewing 5 reply threads
