May 30, 2022 at 8:01 am
socra
SubscriberHello everyone.
I'm simulating two objects to be coupled. One is a rigid body while the second one is a bag. I need to move the rigid body to a defined position. In the ls dyna version 971 I impose the rigid constrains and to move the object I impose a displacement. Everything works well. In the version R11, when I do the same thing, a WARNING 30120 occurs (The y-translational degree of freedom rigid body XX is restrained but has a velocity boundary condition applied . The velocity will be set to zero.
How can I apply the motion on a rigid, constrained body on the new version of LS DYNA?
Thanks
May 31, 2022 at 12:13 pm
Ram Gopisetti
Ansys EmployeeAre you implying both the BC on to same body?, How about CNRB and apply prescribe motion rigid card? have you tried that?
Cheers, Ram
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
3648
2534
1745
1226
580
