December 29, 2022 at 7:05 pm
Bryce Teaford
SubscriberHello,
I am an Ansys Maxwell 2022 R1.2 user. I have been trying to add motion to my band to make a cylindrical magnet inside of it translate back and forth using the function 33.53*cos(36.4*pi*Time), and the units should be in inches_per_sec. The velocity units never save when I put the function in. Leading to my conclusion that this is where the problem is. I have selected inches per second multiple times and have ran the simulation, but to no avail, I get the same error:
"Error in mesh mapping on band. please check the potential problem in band setting. 114"
I have gone through the process of creating a band (a polyhedron of 150 segments) around my magnet, defining the type as periodic translation, and entering the function in the velocity field multiple times. At this point, I know it is likely something simple I am missing and would very much appreciate any help in fixing this problem.
Thank you! -
January 5, 2023 at 11:42 am
Navya C
Ansys EmployeeHi Bryce,
Can you share screenshots of your model showing how the band is assigned?
Navya
January 9, 2023 at 7:19 pm
January 5, 2023 at 6:47 pm
Bryce Teaford
Subscriber -
January 10, 2023 at 9:51 pm
Howard
Ansys EmployeeHello Bryce,
Could you run validation check? Please unselect "Periodic" in Type tab of Motion propperties.
HDLI
January 11, 2023 at 6:57 pm
February 2, 2023 at 3:10 am
Bryce Teaford
SubscriberHello, I am still looking for help on this topic.
- Maxwell, HFSS or Q3D?
- Error
2630
2104
1327
1110
461
