July 23, 2023 at 6:23 pm
Bahaddin Göksun
SubscriberI am designing a Permanent Magnet Synchronous Generator in the Motor-Cad application, specifically in the BPM tab. I need to operate the model in lagging mode, using a sine wave as the drive signal. However, I couldn't determine the exact point of phase angle where the machine should operate in lagging mode, and for the lagging mode points that I have found, lagging power factor has minus sign. Is it correct? Thanks for your answer.
August 2, 2023 at 7:19 pm
Faezeh Ladani
Ansys EmployeeHi Bahaddin,
The question goes beyond the scope for Ansys Employee to answer on a public forum. Hopefully, other forum users chime in. Also, if you have access to customer portal, please submit a ticket and our engineers will work with you one-on-one on that.
- Maxwell, HFSS or Q3D?
- Error while solving Optimetrics
- Error
- Concept of Interpolation Sweep in HFSS
7742
4502
2961
1449
1322
